21 years agoHow to boot uClinux automatically
Hi, Please explain to me how to boot uClinux kernel and filesystem and Nios2 configuration, when power on the Altera Nios2 cyclone development board. I need to download the FPGA configuration t...
21 years ago --- Quote Start --- originally posted by coolman@Feb 14 2005, 01:46 AM hi,
i tried to download the kernel-project and the hardware design with flashprogrammer, but it failed. then i downloaded the hardware design file (.pof) with quartus programmer and byteblasterii to epsc4-device and the kernel project with flashprogrammer to flash, it worked succesfully!
now i don't have to download .sof-file each time when powering on the board.
but tell me, how i can get the rid of starting the uclinux with terminal console. i want that uclinux starts running immadiately when i turns the power on.
-coolman --- Quote End --- CoolMan, Could you tell me which hardware configuration you are using now (.pof)? You build your kernel and filesystem based on that file? Why not use .sof file? Thanks, Neo
