21 years agoHow to boot uClinux automatically
Hi, Please explain to me how to boot uClinux kernel and filesystem and Nios2 configuration, when power on the Altera Nios2 cyclone development board. I need to download the FPGA configuration t...
21 years agoI would do the following:
(1) Ensure that your hardware design's reset location is set to the beginning of flash (2) Upload the hardware design into flash (3) Build a kernel to match the hardware design (4) Upload the kernel to flash If you have an Altera board, you could use the "standard" example quartus project as a starting point. Build a kernel using the default configuration minus the IDE controller and upload both the quartus project and kernel to flash. The next time you restart the board, Linux should start up.
