19 years agoHow to add second flash to MTD
I am using a board with 2 16 MB CFI flashes. Flash 1 at 0x0 and Flash at 0x02000000. uClinux detects flash 1 and does not detect flash 2. I am using microtronix map where i see, It sends dat...
19 years agoI thnik its better to use them separately]. Just specify the address of second chip in the map file.
mtd cat is used if you want to have single file system spread on two chips, which is not what you want. [i have not used it yet] Should work.
