22 years agoHow to Add EPCS_Controller in Custom Target Board?
I follow the instruction in "Nios II Flash Programmer's Guide" to make a Custom Target Board. But I find that, i can only use ASMI(Active Serial Mem. Interface) in this target board's Nios...
22 years agoI had the same question when we did our target board. But, in the end, it didn't matter. The target board is only used for programming the flash and EPCS devices. I think that the code that Altera sticks in the on-chip RAM uses the ASMI device and not the EPCS controller. So, in answer to your question, you don't need to use the EPCS controller in your board.
