21 years agoHow to add an userlogic to the tri-state bridge?
I want add an user logic in CPLD to NiosII which resides in FPGA, the logic is some registers and I want to add it to the tri-state bridge, thus Nios can write or read these registers through the tri...
21 years agoThank you for your intensive explanation.
I'll try it after a while. But, there may be an alternative as for the hdl interface file: if you do not specify a hdl file under the HDL FILES tab, add signals under the SIGNALS tab may also be ok. I'll try them. Thank you. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif
