22 years agoHow to access IDE Hard Disk
How to access IDE Hard Disk 1. Implemented by software: A File system and driver for IDE in uc/OS running onNios can read the data from IDE disk. 2. Implemented by Hardware: A IDE Co...
22 years agoI find a Reference Design in HDK of APEX Nios Dev. Board, called "IDE_demo":
<div class='quotetop'>QUOTE </div> --- Quote Start --- The IDE sample design includes a simple file system for demonstration purposes. A single directory is supported, with named, byte-oriented files, and a "write-once-read-many" model. (That is, bytes can only be added to the very end of the very last file.) Sample perl scripts are provided that convert text files into a file system image which can be downloaded to an IDE hard drive.[/b] --- Quote End --- I wonder who test it and apply it to some application? how about the performance?
