13 years agoHow to access a NIOS II ALU instruction from an application code?
This question might sound trivial, however since I am a beginner I am forced to ask this as well. How to call the NIOS II ALU ADD instruction from an application code in C which runs on NIOS II IDE? I searched in the manuals however could not find a good direction. add rC, rA, rB is the assembly instruction for it. (However I need a C equivalent) I see the HAL folder in the NIOS II which has many abstraction functions, so I was wondering are there any IO layer function equivalents which I can use for ADD (which goes and access the driver level functions) ? Or some macros (which are built during the entire build process). Please help me out here. Thank You, Akhil1 Reply
Just use the "+" operator naturally in C.
int add(int a, int b) { return a+b; }
