16 years agoHow the avalon mm slave "address alignment" works?
Hi everyone I use avalon mm slave port with conduit to interface a 16bits peripheral, but everytime when i READ the peripgheral, the data readback can not in correct address when inspected in...
16 years agoHi
thanks for ur help would be great if u can send me an example i don t understand why i have to use 0x0, 0x4, 0x8, 0xC, etc... but at all that i tried already and didn t worked aswell :/ i m using the offset adress only for intern adressfinding i don t access an RAM or something like that i only want to write or read different things from my own HDL to the NIOS i set the readlatency to 5 i ll try to set it to 1 maybe that helps and the main question i m using a 8 Bit Adress so i have HEX from 00 to FF if i m using now 8'h00, 8'h04, 8'h08, 8'h0C ... in the HDL do i give the adress the same in the NIOS ? or do i need there 0x00 0x01 and so on? or 0x00 0x04 0x08 ??? dunno sometimes i get an adress access but sometimes i don t dunno why :(
