16 years agoHow the avalon mm slave "address alignment" works?
Hi everyone I use avalon mm slave port with conduit to interface a 16bits peripheral, but everytime when i READ the peripgheral, the data readback can not in correct address when inspected in...
16 years agoGiven that the nios2 cpu always does 32bit memory accesses, and that these get converted into two 16bit cycles to access a 16bit target, it might be worth making your peripheral have a 32bit interface and just ignore the high bits?
The 32bit MM bus doesn't have address lines for the bottom 2 address bits, writes use 4 byte enable lines, and (IIRC) reads are always 32bit. It might be that the ADR0 line corresponds to value 4.
