20 years agohow I "set the BUILD_CC environment variable "?
hi all: I am porting ncurses-5.5 to nios2 uclinux now. Frist I edit configure.sub add " | nios2 " in the "case $basic_machine in" then I run: ./configure --build=nios2 --with-...
20 years agohi:
I don't find ncurses lib in uClinux-dist-test. I just find nessus app in /user. Can you tell where id the ncurses lib? Thank you
