20 years agohow I "set the BUILD_CC environment variable "?
hi all: I am porting ncurses-5.5 to nios2 uclinux now. Frist I edit configure.sub add " | nios2 " in the "case $basic_machine in" then I run: ./configure --build=nios2 --with-...
20 years agohi hippo:
Thanks for you reply. Frist I have successed make ncurese by you guide. Then I must cross compile cdk(curses d k).It is a devlope tool for ncurses. I still edit configure.sub and use configure option as your post. but not select crosscompile option in configure process. [alex@localhost cdk-5.0-20060220]$ ./configure --host=nios2-linux-uclibc --with-build-cc=gcc --disable-shared loading cache ./config.cache checking for X... (cached) libraries /usr/X11R6/lib, headers /usr/X11R6/include checking host system type... nios2-altera-linux-gnu (cached) Configuring for linux-gnu checking for package version... 5.0 checking for package patch date... 20060220 checking for gcc... (cached) gcc checking whether the C compiler (gcc ) works... yes checking whether the C compiler (gcc ) is a cross-compiler... no checking whether we are using GNU C... (cached) yes I try another ./configure option, for example: [alex@localhost cdk-5.0-20060220]$ ./configure --build=nios2 --host--nios2-linux-uclibc --with-build-cc=gcc --disable-shared [alex@localhost cdk-5.0-20060220]$ ./configure --host--nios2-linux-uclibc --with-build-cc=nios2-linux-uclibc-gcc --disable-shared etc.... but I still fail. Please help me. If I make success, I will test the ncurses in my dvb. Then post porting method to forum.The ncurses is a very helpful terminal tool for us.It can make tab,menu, ....in a terminal like a Kernel make menuconfig windows.
