21 years ago
How do mount CF card in uClinux1.3
who can kindly tell me , how can mount CF card? I can deceter CF card , but always can't mount..........
regard
elliott
Linux version 2.6.9-uc0 (user@elliottnb) (gcc version 3.4.1 (Altera Nios II 1.1
b137))# 2 Tue Jun 14 15:14:32 2005
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
Built 1 zonelists
Kernel command line: root=/dev/mtdblock0 ro
PID hash table entries: 128 (order: 7, 2048 bytes)
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory available: 14220k/16384k RAM, 0k/0k ROM (1631k kernel code, 338k data)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
NET: Registered protocol family 16
Serial: JTAG UART driver $Revision: 1.3 $
ttyJ0 at MMIO 0x80920820 (irq = 1) is a jtag_uart
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
smc_probe: 75000 Khz Nios
SMSC LAN91C111 Driver (v2.1), (Linux Kernel 2.6)
eth0: SMC91C11xFD(rev:1) at 0x80910300 IRQ:6 MEMSIZE:8192b NOWAIT:0 ADDR: 00:07:
ed:0a:05:24
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
CF: ctl=1
hda: SanDisk SDCFB-512, CFA DISK drive
Using anticipatory io scheduler
ide0 at 0x80920900-0x80920907,0x80920938 on irq 5
hda: max request size: 128KiB
hda: 1000944 sectors (512 MB) w/1KiB Cache, CHS=993/16/63
hda: hda1
Altera NDK flash (AMD): Found 1 x8 devices at 0x0 in 8-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
Altera NDK flash (AMD): CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
cmdlinepart partition parsing not available
RedBoot partition parsing not available
Using Altera NDK partition definition
Creating 4 MTD partitions on "Altera NDK flash (AMD)":
0x00200000-0x00600000 : "romfs/jffs2"
0x00000000-0x00200000 : "loader/kernel"
0x00600000-0x00700000 : "User configuration"
0x00700000-0x00800000 : "safe configuration"
NET: Registered protocol family 2
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 1024 bind 2048)
NET: Registered protocol family 17
VFS: Mounted root (romfs filesystem) readonly.
Freeing unused kernel memory: 52k freed (0x11cc000 - 0x11d8000)
expand: from=/ramfs.img to=/dev/ram0
expand: from=/ramfs.img to=/dev/ram1
/etc/issue www.microtronix.com July 2004
Welcome to Linux on the Nios II
Nios2 login: nios
Password:
# mount -t vfat /dev/hda1 /mnt/ide0 -n
hda: hda1
FAT: codepage cp437 not found
hda: hda1
mount: wrong fs type, bad option, bad superblock on /dev/hda1,
or too many mounted file systems#
1 Reply
    You will need to add Codepage cp437 support to your kernel to mount that particular vfat partition. It can be found in the kernel configuration under...
    File systems --->
    Native Language Support --->
    < > Codepage 437 (United States, Canada)
    Dennis Scott
    Microtronix Datacom
