22 years agoHow do I rebuild the ramfs.img file?
I am doing this development using a cyclone board with a custom FPGA configuration. With this build the kernel and ROM file system seem to work fine but I have no access to the ram file system. I ass...
22 years agoHello Halfdome,
Are you using Nios II with the MicroC-OS/II Software Component Read-only file system? This file system only runs out of flash, not out of RAM. The Webserver example in the Nios II IDE is an example of how to use that read-only filesystem. If not, what ram file system are you referring to? Best regards, Stephen O'Reilly Altera Embedded Applications Engineering
