20 years agoHow do I get SSRAM to run at 125MHz?
I have a design with two processors. One processor uses MRAM connected via a TCM interface as its instruction memory, and some M4Ks for data memory. The other processor uses SSRAM as its data and ins...
20 years ago --- Quote Start --- originally posted by svhb@Sep 1 2006, 06:13 AM for the cycloneii kit, i had the same problem.
i adjusted the skew to -1.5ns, then the ssram worked on 120mc.
so indeed it is a matter of adjusting the skew to the correct value. trial and error, or following the description in the ssram core manual.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18007)
--- quote end ---
--- Quote End --- I tried -4.8ns and it verified the code after downloading it from the IDE, but nothing happened after that. I'm doing a compile with -1.5ns now. Has anyone successfully used SSRAM at 125 (or higher) MHz on a Stratix II development kit? If so what skew did you use for the SSRAM clock? Alternatively, what signals should I be looking at on a logic analyzer to determine what the ideal skew for my design is? SSRAM uses quite a few more signals than the mictor connector provides.
