20 years agoHow do I get SSRAM to run at 125MHz?
I have a design with two processors. One processor uses MRAM connected via a TCM interface as its instruction memory, and some M4Ks for data memory. The other processor uses SSRAM as its data and ins...
20 years agoFor the CycloneII kit, I had the same problem.
I adjusted the skew to -1.5ns, then the SSRAM worked on 120Mc. So indeed it is a matter of adjusting the skew to the correct value. Trial and error, or following the description in the SSRAM core manual.
