15 years agoHow do I create .hex or .flash files in IDE?
Hi, I am trying to get the IDE to automatically create a .hex or .flash file each time I build my project in the IDE. I have searched the altera docs and think that what I need is the "...
15 years agoThe application Makefile has a 'mem_init_install' target that uses the BSP mem_init.mk.
Here is the help target from a Nios II application project Makefile for reference help : @$(ECHO) "Summary of Makefile targets" @$(ECHO) " Build targets:" @$(ECHO) " all (default) - Application and all libraries (including BSP)" @$(ECHO) " bsp - Just the BSP" @$(ECHO) " libs - All libraries (including BSP)" @$(ECHO) " flash - All flash files" @$(ECHO) " mem_init_generate - All memory initialization files" @$(ECHO) " mem_init_install - All memory initialization files (copy files to Quartus II project)" @$(ECHO) " Clean targets:" @$(ECHO) " clean_all - Application and all libraries (including BSP)" @$(ECHO) " clean - Just the application" @$(ECHO) " clean_bsp - Just the BSP" @$(ECHO) " clean_libs - All libraries (including BSP)" @$(ECHO) " Run targets:" @$(ECHO) " download-elf - Download and run your elf executable" @$(ECHO) " program-flash - Program flash contents to the board"
