How do I boot HPS of Cyclone V SoC on AMP
Hello ericv,
Thank you. I understood the advantage of the single image thanks to your explanation. I'm still referring uAbassi source codes, but I have no idea about how it release Core#1 and how it indicates to execute App_1 on Core#1. If I have a big misunderstanding, please let me know... And I also referred the document you introduced. This looks very nice to learn the outline of booting and configuration in my Cyclone V SoC. It says "The user software in CPU0 is responsible to release CPU1 from reset.", but unfortunately this document doesn't show how to do that. Is it better to refer Cortex-A9 MP core documents regarding U-boot or more subsequent booting processes? I appreciate for your continuous support! Thanks,- ALTERA-INSUPPORT222 years ago
Assistance Needed: Trouble Running Bare-Metal Code on Cyclone 5 HPS
I am working on intel cyclone 5 hps I have two cores in a processor Core 0 core 1, I want two code to run on two different cores core 0 and core 1 in bare metal .
When I run in jtag mode it works, for jtag i first debug using core 0 where i take core 1 out of reset it, than debug core 1 usign jtag it work
BUT, When i want to run both core usign qspi it only run core 0 not core 1
Here is the step i followedFirsly, loading preloader
quartus_hps -c 1 -o P preloader-mkpimage.binI make an image from bin file of core 0 and place it to qspi
mkimage -A arm -O u-boot -T standalone -C none -a 0x00060000 -e 0 -n "baremetal image" -d core0.bin core0.img
quartus_hps -c 1 -o P -a 0x00060000 core0.img
I make an image from bin file of core 1 and place it to qspi
mkimage -A arm -O u-boot -T standalone -C none -a 0x00100000 -e 0 -n "baremetal image" -d core1.bin core1.img
quartus_hps -c 1 -o P -a 0x00100000 core1.bin
When i restart board only that code work which is in core 0, core 1 code not executingI am setting cpu1startaddress 100000 apart from that in the code of core 0 also i am using alt_qspi function to to place bin file data in ddr,
I want to run in smp mode so I also set required aux_control_register smp and fw bit as stated in tech ref manual
alt_qspi_read((uint32_t *)BL_START/*ddr3 address*/, 0x100000/*qspi address*/, 0x40000);
In linker/scat file core 0 entry point is 0x60000 andlinker/scat file core 1 entry point is 0x100000
