20 years ago
How can I use macro outl in nios2 uclinux?
hi :
I want to use macro( outl(data,address)) access pio directly.
so I include <asm/io.h>.but make fail. The erro information is:undefine ref outl.
But the macro outl is included in <asm/io.h>.
I am so puzzle.
How can I solve it? Thanks a lot.
    --- Quote Start ---
    originally posted by alex824@Apr 27 2006, 01:17 PM
    hi :
    i want to use macro( outl(data,address)) access pio directly.
    so i include <asm/io.h>.but make fail. the erro information is:undefine ref outl.
    but the macro outl is included in <asm/io.h>.
    i am so puzzle.
    how can i solve it? thanks a lot.
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14737)
    --- quote end ---
    --- Quote End ---
    add,# define __KERNEL__
    Thanks hippo
    I lost the "-" in D__KERNEL__ firster. so I make fail. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
    every one:
    If you do not want to write driver for some simple device. You can use macro
    outl , inl to control the device directly.
    frist add "-D__KERNEL__ " to CFLAGS += in your makefile
    second copy "nios2_system.h" from ~/linux2.6.x/include to your include dir
    follow is my simple code:
    # ifndef __LED_H__# define __LED_H__
    # include <asm/io.h>
    # include "board.h"
    // define constants for LED status# define LED_ALL_OFF 0x00# define LED_ALL_ON 0xFF
    # define MAJ_LED_OFF (inl(LED_CTRL) & 0xFE)# define MAJ_LED_ON (inl(LED_CTRL) | 0x01)
    # define MIN_LED_OFF (inl(LED_CTRL) & 0xFD)# define MIN_LED_ON (inl(LED_CTRL) | 0x02)
    # define ACO_LED_OFF (inl(LED_CTRL) & 0xFB)# define ACO_LED_ON (inl(LED_CTRL) | 0x04)
    void init_led(void);
    # endif
    # ifndef __BOARD_H__# define __BOARD_H__
    // Main clck frequency.# define MCLK 50000000
    // SDRAM area definition.# define SDRAM_BASE 0x01000000# define SDRAM_SIZE 0x01000000 // 16MBytes
    //FALSH area definition# define FLASH_BASE 0x00000000# define FLASH_SIZE 0x00800000 // 8MBytes
    // led Configuration Registers# define LED_CTRL 0x00810850
    # endif
    # include "led.h"# include "board.h"
    void init_led(void)
    outl(LED_ALL_ON, LED_CTRL);
    int main(void)
    //init_msgQ();
    init_led();
    while(1)
    outl(LED_ALL_OFF, LED_CTRL);
    outl(MAJ_LED_ON, LED_CTRL);
    sleep(1);
    outl(MAJ_LED_OFF, LED_CTRL);
    sleep(1);
    outl(MIN_LED_ON, LED_CTRL);
    sleep(1);
    outl(MIN_LED_OFF, LED_CTRL);
    sleep(1);
    outl(ACO_LED_ON, LED_CTRL);
    sleep(1);
    outl(ACO_LED_OFF, LED_CTRL);
    sleep(1);
    I use NiosII IDE.
    I add "-D__KERNEL__ " to CFLAGS += in my makefile. cope the nios2_system.h to the project.When build the target, the errors like follows:
    in inclusion d:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0/include/linux/config.h:4[d:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0/include/linux/linkage.h] mult line 4 May 7, 2006 8:27:23 PM
    linux/autoconf.h: No such file or directory[d:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0/include/linux/config.h] mult line 4 May 7, 2006 8:27:23 PM
    nios2_system.h: No such file or directory[d:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0/include/asm/nios.h] mult line 4 May 7, 2006 8:27:23 PM
    in inclusion d:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0/include/linux/linkage.h:4:[d:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0/include/linux/kernel.h] mult line 11 May 7, 2006 8:27:23 PM
    If comment the# includd <asm/io.h>, all the errors like above disappeared .
    What is wrong ? Please give me help?Thank you very much!!
    Copy & Paste does the job, too. You can even use the Altera HAL.
    well, it is just an idea...
    alex824,
    Can you post a simple project on the wiki, or in the forum for us newbies to follow ?
    A complete course code with suitable makefile (standalone) would be good.
