20 years agoHow can I use cs8900a in NIOSII?
I fount that there is no HAL and UCOSII folder in the path of \altera\kits\nios2\components\altera_avalon_cs8900.Then how can i use cs8900a in NIOSII? If I have to write the HAL drive ,is there e...
20 years ago --- Quote Start --- originally posted by cameral@Feb 10 2006, 02:06 AM thanks for the answer of bkucera.it seems that i have to write hal myself. but there are many differences between cs8900 and lan91c11,so it is hard to say whether i can work it out.
is there verilog or vhdl code of cs8900 so i can build a new component in sopcbuilder? --- Quote End --- You don't need hdl to create a cs8900 component. Copy the LAN91C111 folder to a new directory and look at the files inside with a text editor, specifically the PTF file. Rename everything that says LAN91C111 to CS8900, save, and reopen SOPC builder. You should have a CS8900 component now. From there you'll need to modify the PTF file to have the right inputs/outputs, and you'll need to modify the driver code to work with the CS8900.
