16 years agohow can i tell the IDE to carry code to TCM
i write a program with assembly instruction,i want this program can be excuted in tightly coupled memory,but when i debug ,this code is not in the TCM,my TCM name is “onchipmemory",my program is follow:
start: nop call test_code br start .section .onchipmemory test_code: addi sp,sp,-4 stw ra,0(sp) movi r2,0x99 movi r3,0xaa mul r2,r2,r3 ldw ra,o(sp) addi sp,sp,4 ret24 Replies
Now,the problem had been solved.Anyway ,thank you for your help.:p
I'm sorry I couldn't help more... How did you solve it?
the code modified as :
.section .instruction_onchipmemory ,"a" everything is ok. - Altera_Forum
--- Quote Start --- the code modified as : .section .instruction_onchipmemory ,"a" everything is ok. --- Quote End --- It is very good Idea!
