how can i tell the IDE to carry code to TCM
i write a program with assembly instruction,i want this program can be excuted in tightly coupled memory,but when i debug ,this code is not in the TCM,my TCM name is “onchipmemory",my program is follow:
start: nop call test_code br start .section .onchipmemory test_code: addi sp,sp,-4 stw ra,0(sp) movi r2,0x99 movi r3,0xaa mul r2,r2,r3 ldw ra,o(sp) addi sp,sp,4 ret24 Replies
:mad: No one can answer this question?
Did you try
instead? Or have a look at the linker script, to find out what name it gave to your section..section onchipmemory - Altera_Forum
thank you,i am glad to try it again
i tried in different way,but still can't seen the objectcode carried to the TCM,if anyone know how to do this with assembly instruction please tell me,thank you very much!
I have delayed this issue two weeks, please help me, thank you!:mad:
what does your linker script look like? In what section is your code put by the linker?
i can't see and edit the linker file,the file is created by the IDE automatically,can you tell me how to see and edit the linker file? thank you!
If you are using the IDE, it is in your system library > Debug > system_description > generated.x
TO_BE_DONE
From what I can read in the linker script, you don't have any section called onchip_memory. You have instruction_onchipmemory (address 0x08000000) and onchip_memory2_0 (address 0x04000000).
One of those should be your TCM memory. Use its name as section name, without the . in front, and see if it works.
