22 years agoHow can I start different programs from flash.
How can I start different programs from flash. Dependend on a configuration structure in flash I want to start different programs from flash. the reset vector in SOPC Builder should alwa...
22 years agoelf2flash Converts an .elf executable file to a .flash file for programming into flash memory.
Or try page 1–6 of the Nios II Flash Programmer User Guide it's in the install, or on the web. You acn always do searched in pdf docs (not FIND - a SEARCH). This allows you to search all pdf docs for a word (in this case elf). THen you can expand the findings and see which one you want to look at. Tell me if this helps.
