21 years agoHow can i run program in sdram?
I generate a CPU with Onchipram and sdram, and i new a project in NIOS II IDE with template hello_led, when i build this project in onchipram, it works good,and i can access sdram correct, and the...
21 years agoHi,
here are some of the basics: usually IDE creates a folder in your project directory, called software\software_project_name. the source code is stored there. the file for download can be found under software\software_project_name\debug\ and it has the file extension .elf.
