21 years agoHow can i run program in sdram?
I generate a CPU with Onchipram and sdram, and i new a project in NIOS II IDE with template hello_led, when i build this project in onchipram, it works good,and i can access sdram correct, and the...
21 years agohey,friends
I have a question to ask. When NiosII IDE run code,I know it downloads file via the JTAG cable,but which file? -------------Is it in hex format or bin format or something else? -------------Is it located in the code project (where my original code is)or ----------------------------in the hardware project (where *.sof *.pof is)? thanks
