21 years agoHow can i run program in sdram?
I generate a CPU with Onchipram and sdram, and i new a project in NIOS II IDE with template hello_led, when i build this project in onchipram, it works good,and i can access sdram correct, and the...
21 years agoThanks ppk031000.
i`m new to NIOS, bought a board, then according the document with the board build my first CPU, i only use the board not more than 24 hours in my free times. You are right,i should first read the Guide, even my jod`s so busy and most of my sleep time of a day is less than 5 hours recently. so sorry for a dude` question! but i`m not a dude :-) i thought the sof or pof file is include the Code which i wrote in NIOD IDE, now i know it is not, maybe the code store in onchipram is in the sof ot pof file. but sdram not. Thanks!
