21 years agoHow can i run program in sdram?
I generate a CPU with Onchipram and sdram, and i new a project in NIOS II IDE with template hello_led, when i build this project in onchipram, it works good,and i can access sdram correct, and the...
21 years ago --- Quote Start --- originally posted by hugeant@Sep 1 2005, 10:15 AM when i use quartusii->tools->programer->jtag to download&run, it did not works, atfer do that,nothing happened.
so you say the run as hardware is run with jtag, i do not know the difference with the two ways. --- Quote End --- Hey dude You just download the Hardware Image using the Quartus . You need to download the Code using NIOS. Programming using Quartus & Nios are two completely different things. Both need to be done!!! Please go through the Getting started Guide. regards Pavan
