21 years agoHow can i run program in sdram?
I generate a CPU with Onchipram and sdram, and i new a project in NIOS II IDE with template hello_led, when i build this project in onchipram, it works good,and i can access sdram correct, and the...
21 years agowhen i use quartusii->tools->programer->JTAG to download&run, it did not works, atfer do that,nothing happened.
so you say the run as hardware is run with jtag, i do not know the difference with the two ways.
