21 years agoHow can i run program in sdram?
I generate a CPU with Onchipram and sdram, and i new a project in NIOS II IDE with template hello_led, when i build this project in onchipram, it works good,and i can access sdram correct, and the...
21 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- then i build in sdram,when i run as hardware in NIOS IDE II, it also can works,[/b] --- Quote End --- Is it works? <div class='quotetop'>QUOTE </div> --- Quote Start --- but when i complilation in quartusII and download with jtag[/b] --- Quote End --- Run as hardware is download by jtag,too. So what's your real problem? Is it after you recompiling in Quartus, that the system works not properly?
