22 years agoHow can I load a file into memory?
I'm using Nios II Ide to test some imaging software. By now I've used litttle images created pixel by pixel. I'd like to load a bigger image into memory, but I wasn't able.
The C command fopen doesn't work, and I don't want to write the image pixel by pixel (I'd like to try with 640x480). Thanks4 Replies
Sorry, I forgot...
I'm trying to simulate my programs with Nios II ISS (I'm not using a development board, it's only a simulation) Thanks - Altera_Forum
I think this topic got lost for a while. I've emailed someone. Hopefully They'll be able to help. Tell us if you've figured this out.
fopen will only work if you have a filesystem. The only one currently available is the zip filing system which would require you to put your data into an uncompressed zip file and then program this zip file into flash.
As for getting data into memory you can just put your binary file through objcopy to convert into elf format with symbols around it. This will then be available in memory. Hope that helps - Altera_Forum
Did you solve your problem?
Tell us if you didn't.
