20 years agoHow can I go into the "hwselect" window ?
Everyone When I do the Step3,in which I need to do LinuxHwselect , I cannot make it. Where can i find the right diretory to go into the following screen: --- Please select which CPU you wish to build the kernel against: (1) cpu - Class: altera_nios2 Type: s Version: 5.11 Selection: 1 --- Please select a device to upload the kernel to: (1) ext_flash Class: altera_avalon_cfi_flash Size: 16777216 bytes Selection: 1 --- Please select a device to execute kernel from: (1) ext_ssram Class: altera_avalon_cy7c1380_ssram Size: 2097152 bytes (2) ddr_sdram Class: ddr_sdram_component Size: 33554432 bytes I tried the ~/uClinux-dist-test dir ,but I cannot go into. So I tried ~/uClinux-dist-test/linux2.6.x,and see the correct acreen, But is it all right??? Thanks!!4 Replies
I also have met the similar problem today , did not know how to solve.
I have done with it porperly!
[oneuser@RJ uClinux-dist-test]$make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- linux_hwselect SYSPTF=nios_0.ptf u can find a makefile file in dir "uClinux-dist-test",which contains info. like this: ... linux_xconfig: KCONFIG_NOTIMESTAMP=1 $(MAKEARCH_KERNEL) -C $(LINUXDIR) xconfig linux_menuconfig: KCONFIG_NOTIMESTAMP=1 $(MAKEARCH_KERNEL) -C $(LINUXDIR) menuconfig linux_config: KCONFIG_NOTIMESTAMP=1 $(MAKEARCH_KERNEL) -C $(LINUXDIR) config linux_hwselect: KCONFIG_NOTIMESTAMP=1 $(MAKEARCH_KERNEL) -C $(LINUXDIR) hwselect ... I think it will help you understand the command. Note: nios_0.ptf must be in the dir /uClinux-dist-test/linux-2.6.x - Altera_Forum
The steps to rebuild completely from a clean set goes:
make clean make linux_hwselect SYSPTF=insertyourptfhere.ptf make make linux make image The previous reply is correct that the PTF file needs to be in the kernel's base directory... in my case the linux-2.6.x directory. In case you would like to know more about it, the Makfile that eventually gets called to do the actual work is in uClinux-dist-test/linux-2.6.x/arch/nios2nommu/ And the PERL scripts that it uses are in the scripts folder. The script that asks you the questions is hwselect.pl and the script that generates the nios2_system.h file are gen_nios2_system.h.pl. Your answers to the questions are stored in the hardware.mk file. - Altera_Forum
make linux_hwselect SYSPTF=~/your_project/your_system.ptf
no need to copy the ptf, but you should give the path to your ptf.
