15 years agohow can I convert .srec to .flash or .bin?
When I use nios2-srec2flash to convert .srec to .flash I get the following message: nios2-srec2flash xxxxx.SREC flash address: 0x00140000 ram address: 0x00040000 max copy size: 0x0...
15 years agosrec_cat is part of srecord (http://srecord.sourceforge.net/) (on Sourceforge).
A .flash file is (for the most part) an SREC. In fact, the Nios II flash programmer can program SRECs directly, provided the address offsets are from the base address of the device you're programming to. Cheers, slacker
