20 years agoHow can i build a tftp server in u-boot?
I use the u-boot run my embedded system in nios2 platform. In the first time,I must use the tftp download my imag file to the sdram, but there are no tftp server in the u-boot.I must operate com...
20 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- Hi smalllight, could you please explain how you did so. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15253) --- Quote End --- [/b] --- Quote End --- Hi, MFM In the fact,the tftp server is very similar with a tftp client In the u-boot, there are no the code about WRQ. if a tftp client want transport a file to tftp server. it will send a WRQ to tftpserver,the tftp server will send a ACK to client when the receive the WRQ packet. then the client will transport the fill 512 bytes in once. when the server receive the data packey,it send a ACK packet to client. if the data length is smaller than 512 bytes, the file transport success. so I add some code to ask the WRQ packet in the function TftpHandle and change the TftpOurPort to WELL_KNOWN_PORT and you must Save the Client IP when you receive the ARP packet. Before your work,you should read the tftp protcol document.
