20 years agoHow can i build a tftp server in u-boot?
I use the u-boot run my embedded system in nios2 platform. In the first time,I must use the tftp download my imag file to the sdram, but there are no tftp server in the u-boot.I must operate com...
20 years agoHi smcnutt!
thank you for you help. my english is very poor, I don't discribe my problem clearly. why do i must change my PC ip to download the image file? the reason as follon: first, i don't want to use the command line in u-boot. second,Maybe,I download the image file in diffrent PC for example,the ip of my embed board is 192.168.168.1 I set the serverip=192.168.168.100 now if the ip of my pc is 192.168.168.99 in this case, if i want to download my image file, i must use the command line of u-boot to change the env serverip or i change the ip of my pc to 192.168.168.100 ,or i will no way to download my image file. if i have a tftf server in u-boot. i can input the command "tftp -i 192.168.168.1 put image.rom" in the cmd in my pc. do you understand?
