21 years agoHow can I add the ecos to the Nios II RTOS combo
Hi: We know that when I compiled a common "c/c++ Application",there are RTOS combo in the system library ,which includes: none(single-thread) and MicrC/OS-II . now ,I had set up the ecos ...
21 years agoI'm not certain what your question is here, but if I understand you correctly, you should only use an "Advance c/c++" project for eCos, not the standard "c/c++ Application".
