19 years agoHost based and Read only Zip files
Hi all, I got a certain code that I need to run having an input file. I download my program to RAM in general and just use the flash for the file when using the "rozipfs". I tried using once...
19 years agoFlash/rozipfs will be much faster. Hostfs is going over a GDB link to your PC.
With respect to your other question, I'm not sure why you're seeing a significant slowdown when using hostfs, however, you'll never be using hostfs in a real-world embedded system, so I can't see that it matters much anyway http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif Cheers, - slacker
