19 years agoHooks for own tools during Quartus Compilation?
Hi, we'd like to embed a number that identifies a particular FPGA configuration in it (the SYS ID isn't sufficient because it doesn't change if only logic outside the SOPC was modif...
19 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- You could create an Avalon mapped component that instantiates a ROM[/b] --- Quote End --- Well I have not been clear about my actual question. I didn't mean to ask what the script to embed the number should do, but rather: how to ensure this script is executed when (or immediately before) selecting "Compile" in Quartus. Experience shows that steps that can be omitted will be omitted, and that's not acceptable in this case... And it would be same with a selfmade build script that has to be executed "outside Quartus". It would be used only in special cases (i.e. when specifically asked to do so) but it really should be used _always_. So I'm actually looking for a hook for such script, in the build process that is triggered from Quartus' menu.
