19 years agohi,hippo Frambuffer build error!
hi, hippo When I build Micrwindows,failed. /home/guor/nios2/dev/uClinux-dist-20070130/uClinux-dist/user/microwin/src/include/device.h:647:20: operator '==' has no left operand ...
19 years agoI have not used microwin with NIOS, but on arm.
check the config file of microwindows if this is set correcty ...# #################################################################### # The pixeltype of the native hardware or underlying graphics library.# This definition defines the PIXELVAL to be 32, 16 or 8 bits wide.# If using Linux framebuffer, set to MWPF_TRUECOLOR0888, and use fbset.# It also enables GdArea/GrArea for this particular pixel packing format.# # define MWPF_PALETTE /* pixel is packed 8 bits 1, 4 or 8 pal index*/# define MWPF_TRUECOLOR8888 /* pixel is packed 32 bits 8/8/8/8 truecolor w/alpha*/# define MWPF_TRUECOLOR0888 /* pixel is packed 32 bits 8/8/8 truecolor*/# define MWPF_TRUECOLOR888 /* pixel is packed 24 bits 8/8/8 truecolor*/# define MWPF_TRUECOLOR565 /* pixel is packed 16 bits 5/6/5 truecolor*/# define MWPF_TRUECOLOR555 /* pixel is packed 16 bits 5/5/5 truecolor*/# define MWPF_TRUECOLOR332 /* pixel is packed 8 bits 3/3/2 truecolor*/# # ################################################################### SCREEN_PIXTYPE = MWPF_TRUECOLOR888
