21 years agoHigh Speed USB 2.0 Hosting
Hi, We are interested in implementing a High Speed (HS) USB 2.0 host that will be running under uClinux and I would be interested to know if anyone has implemented one in their design. I also ...
21 years agoHi Brad, in the v1.4 release of Nios II Linux, we've included support for the ISP1161A1. I'm a little hazy on the specs, but I believe its a USB 2.0 compliant device that supports full and low speed devices. Like the ISP1761, it provides support for 2 host ports and 1 slave port.
-- begin shameless plug -- Microtronix is currently selling a dev kit called the Product Starter Kit. The kit is modular by design. The main Kit is a baseboard with a Firefly module, 1 full santa cruz header, and 1 reduced santa cruz header. Along with the main Kit, you can purchase our Ethernet USB Expansion Kit. The kit contains a santa cruz expansion board with the Phillips isp1161a1 chip and the Davicom DM9000 chip. Both of which are supported under Linux. product starter kit (http://www.microtronix.com/product_firefly_dev.htm) -- end shameless plug -- As for benchmarks, we haven't performed any at this time... so I don't have that information available. Hope this helps
