13 years agoHi, I m using the multiprocessor tutorial, to have a MPSOC application, but when i
Hi, I m using the multiprocessor tutorial, to have a MPSOC application, but when i finish all steps and running the nios application I have this message in the terminal, using cable "us...
13 years agoI'm working with the sdram, I think that s ok with the clock because I'm using a standard design with worked with single processor ( I have added only an other cpu and timer mutex and shire memory) if you have an idea how to redefine clocks I will be thankful :)
