13 years agoHi, I m using the multiprocessor tutorial, to have a MPSOC application, but when i
Hi, I m using the multiprocessor tutorial, to have a MPSOC application, but when i finish all steps and running the nios application I have this message in the terminal, using cable "us...
13 years agoThe "verify failed" error shows there is a problem between the CPU and the memory. What memory are you using? Is your Quartus project properly constrained (are all the clocks defined and recognized by Timequest) and does it meet all timing requirements?
