13 years agoHi, I m using the multiprocessor tutorial, to have a MPSOC application, but when i
Hi, I m using the multiprocessor tutorial, to have a MPSOC application, but when i finish all steps and running the nios application I have this message in the terminal, using cable "us...
13 years agoI have done all your recommended steps but after downloading the first .elf in the first cpu I have the some message than eclipse, also it's the some for the second cpu :(
[NiosII EDS]$ nios2-download -g -i 0 multi_hello_1.elf Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Reading System ID at address 0x05609590: verified Initializing CPU cache (if present) OK Downloaded 70KB in 1.2s (58.3KB/s) Verifying 05604020 (99%) Verify failed between address 0x5604020 and 0x56041C7 Leaving target processor paused and when i had downloding the second .elf in the scomd cpu what can I do it's really a big problem for the advancement of my project and thank you .
