13 years agoHi, I m using the multiprocessor tutorial, to have a MPSOC application, but when i
Hi, I m using the multiprocessor tutorial, to have a MPSOC application, but when i finish all steps and running the nios application I have this message in the terminal, using cable "us...
13 years agoAre you running it from the command line or from eclipse? From the command line you should add a -g option to nios2-download to start the processor after downloading the application. If you are running from Eclipse you could need to tick a box asking to start the processor (I don't use Eclipse so I don't really know).
