rkaib's avatar
rkaib
7 years ago
hi evryone, can anybody plz tell me how hex data is stored in onchip memory de2-115, because i am reading from onchip memory using nios2 but data is different from the hex file stored in it
  • FawazJ_Altera's avatar
    FawazJ_Altera
    Once your hex file is generated in Nios II eclipse, you can use it as initialization file for the on-chip memory. This option is available inside Platform Designer, On chip memory parameters
    By enabling "Enable non-default initialization file" you can select your hex as initialization file for this memory.
  • rkaib's avatar
    rkaib
    hi FJumaah,
    that 's what I have done, but the problem is that the data I am reading are different from the data of the hex file
    in nios2 I am declaring memory as:
    #define mem (unsigned char*) ONCHIP_MEMORY_0_BASE, then
    I am reading: printf("%d, %d, %d\n\r",*mem,*(mem+1), *(mem+2) );
    but the data printed on the console are different if you compare them with the first 3 data of the hex file and I get different data when I power on again the board, really strange!!!
    would you have any clue about it
    FawazJ_Altera
    is the data completely different?
    I suspect this might be due to Endian issue (Big or little).
    thanks
