20 years agohelp!how to build uclinux on de2 in windows
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ohmy.gif
nearly all of those exllent people who built a uclinux on de2 were doing there work in linux environment.have anyone built one in windows environment?how?i'm not so familiar with linux, but i have to done this in a few days, may anyone show me the way?9 Replies
--- Quote Start --- originally posted by tgbzsq@Jul 12 2006, 01:06 AM http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/ohmy.gifnearly all of those exllent people who built a uclinux on de2 were doing there work in linux environment.have anyone built one in windows environment?how?i'm not so familiar with linux, but i have to done this in a few days, may anyone show me the way?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16798)
--- quote end ---
--- Quote End --- even when you have limited time, the fastest way is still working on Linux. first, try out the prebuild image, http://nioswiki.jot.com/wikihome/operating...s/tryoutuclinux (http://nioswiki.jot.com/wikihome/operatingsystems/tryoutuclinux) follow this to install colinux on your windows xp. http://nioswiki.jot.com/wikihome/operating...ms/nios2colinux (http://nioswiki.jot.com/wikihome/operatingsystems/nios2colinux) then install binary toolchain to colinux and install uClinux-dist-test, http://nioswiki.jot.com/wikihome/operating...binarytoolchain (http://nioswiki.jot.com/wikihome/operatingsystems/binarytoolchain) http://nioswiki.jot.com/wikihome/operating...ems/uclinuxdist (http://nioswiki.jot.com/wikihome/operatingsystems/uclinuxdist)
--- Quote Start --- originally posted by hippo+jul 12 2006, 10:34 am--><div class='quotetop'>quote (hippo @ jul 12 2006, 10:34 am)</div>--- quote start ---
<!--quotebegin-tgbzsq@Jul 12 2006, 01:06 AM http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/ohmy.gif
--- quote end ---
--- Quote End --- even when you have limited time, the fastest way is still working on Linux. first, try out the prebuild image, http://nioswiki.jot.com/wikihome/operating...s/tryoutuclinux (http://nioswiki.jot.com/wikihome/operatingsystems/tryoutuclinux) follow this to install colinux on your windows xp. http://nioswiki.jot.com/wikihome/operating...ms/nios2colinux (http://nioswiki.jot.com/wikihome/operatingsystems/nios2colinux) then install binary toolchain to colinux and install uClinux-dist-test, http://nioswiki.jot.com/wikihome/operating...binarytoolchain (http://nioswiki.jot.com/wikihome/operatingsystems/binarytoolchain) http://nioswiki.jot.com/wikihome/operating...ems/uclinuxdist (http://nioswiki.jot.com/wikihome/operatingsystems/uclinuxdist) <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16802)</div> [/b] --- Quote End --- Thank you very much for you answer, i'm going to solve this problem in linux now ,even though i'm not very familiar with it , would you please show me the flow? i still cannot find a development environment for my de2 board under linux, how can i go on my work without Quartus and NIOSII? thus ,the most important thing for me now is find out a suitable develop software under linux.
You should try out the zImage first. It will give you hand on immediately.
If you have extra PC to run Linux, you can install Fedora Core 5 . Otherswise, you can install colinux on your windows xp. look at the wiki, http://nioswiki.jot.com/%c2%b5clinux (http://nioswiki.jot.com/%c2%b5clinux) - Altera_Forum
Microtronix Linux Extensions Version 1.4, Built June 20, 2005 ------------------------------------------------ /cygdrive/f/workspace/altera/NIOS/de2/DE2_demonstrations/DE2_NET [SOPC Builder]$ nios2-download -g Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Restarting target processor /cygdrive/f/workspace/altera/NIOS/de2/DE2_demonstrations/DE2_NET [sopc builder]$ nios2-terminalnios2-terminal: connected to hardware target using jtag uart on cable
nios2-terminal: "usb-blaster [usb-0]", device 1, instance 0
nios2-terminal: (use the ide stop button or ctrl-c to terminate) this is the response of the system after i download the project DE2_NET, and another problem is shown below 系统找不到指定的路径。 . . Removing old PATH, because a copy of . cygwin1.dll was found at: . /usr/bin/cygwin1.dll . You can remove or rename it to avoid conflict. . ------------------------------------------------ Welcome To Altera SOPC Builder Version 5.1, Built Thu Oct 20 19:10:26 PDT 2005 ------------------------------------------------ ------------------------------------------------ Welcome to the Nios II Development Kit Version 5.1, Built Fri Oct 21 00:44:38 PDT 2005 Example designs can be found in /cygdrive/c/altera/kits/nios2_51/examples ------------------------------------------------ (Executing user startup script: c:/altera/kits/nios2_51/user.bashrc) /cygdrive/f/workspace/altera/NIOS/de2/DE2_demonstrations/DE2_NET [sopc builder]$ nios2-download -g zimage_cpu_0
nios2-elf-objcopy: './zimage_cpu_0': no such file
./zimage_cpu_0.srec: unable to open input file
rm: cannot remove `./zimage_cpu_0.srec': no such file or directory
/cygdrive/f/workspace/altera/nios/de2/de2_demonstrations/de2_net
[sopc builder]$ i thought it will show the message that "Starting processor at address 0x04800000" would you please show my a way to explain and solve these problems?
1. in quartus, open the project DE2_System/DE2_demonstrations/DE2_NET/
tool->programmer , program the sof to your board. 2. use web brower to download the zImage_de2_net file to a dir, eg, c:/temp http://nioswiki.jot.com/wikihome/operating.../zimage_de2_net (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/tryoutuclinux/zimage_de2_net) 3. from Windows Start-->Programs-->Altera-->Nios II 6.0 -->Nios II Command Shell 4. in nios2 command shell, cd to that dir, cd /cygdrive/c/temp nios2-download -g zImage_de2_net 5. then nios2-terminal - Altera_Forum
nioswiki.jot.com is not working ... any alternative or any straightforward solution to download uclinux on ALtera de2 board for new bie .. thanks in advance ...
AFAIK, there is no prebuilt Linux for NIOS. It is a work in progress and needs to be tweaked according to the application anyway.
see: http://www.alterawiki.com/wiki/linux_for_the_nios_ii_processor -Michael - Altera_Forum
thanx for updating me Micheal
While following all the steps on tryOutuClinux I am stuck at
make vendor_hwselect SYSPTF=/path_to/your_sytem.ptf I can find /opt/altera8.0/nios2eds/examples/verilog/niosII_cycloneII_2c35/full_featured/NiosII_?cycloneII_2c35_full_featured_sopc.ptfbut having this root@ubuntu:/home/elysium/uclinux/nios2-linux/uClinux-dist# make vendor_hwselect SYSPTF=/media/96A00F1FA00F0609/altera/91/nios2eds/examples/verilog/niosII_cycloneII_2c35/full_featured/NiosII_cycloneII_2c35_full_featured_sopc.ptf make ARCH=nios2 -C vendors vendor_hwselect make[1]: Entering directory `/home/elysium/uclinux/nios2-linux/uClinux-dist/vendors' make -C /home/elysium/uclinux/nios2-linux/uClinux-dist/vendors/Altera/nios2/. dir_v=/home/elysium/uclinux/nios2-linux/uClinux-dist/vendors/Altera/nios2/. -f /home/elysium/uclinux/nios2-linux/uClinux-dist/vendors/vendors-common.mak vendor_hwselect make[2]: Entering directory `/home/elysium/uclinux/nios2-linux/uClinux-dist/vendors/Altera/nios2' [ -d /home/elysium/uclinux/nios2-linux/uClinux-dist/romfs/$i ] || mkdir -p /home/elysium/uclinux/nios2-linux/uClinux-dist/romfs make ARCH=nios2 CROSS_COMPILE=nios2-linux-uclibc- -C /home/elysium/uclinux/nios2-linux/uClinux-dist/../linux-2.6 O=/home/elysium/uclinux/nios2-linux/uClinux-dist/linux-2.6.x hwselect make[3]: Entering directory `/home/elysium/uclinux/nios2-linux/linux-2.6' GEN /home/elysium/uclinux/nios2-linux/uClinux-dist/linux-2.6.x/Makefile scripts/kconfig/conf -s arch/nios2/Kconfig# # configuration written to .config# include/config/auto.conf:8:warning: symbol value 'arch/x86/configs/i386_defconfig' invalid for ARCH_DEFCONFIG include/config/auto.conf:44:warning: symbol value 'elf32-i386' invalid for OUTPUT_FORMAT make[4]: *** No rule to make target `hwselect'. Stop. make[3]: *** [sub-make] Error 2 make[3]: Leaving directory `/home/elysium/uclinux/nios2-linux/linux-2.6' make[2]: *** [vendor_hwselect] Error 2 make[2]: Leaving directory `/home/elysium/uclinux/nios2-linux/uClinux-dist/vendors/Altera/nios2' make[1]: *** [vendor_hwselect] Error 2 make[1]: Leaving directory `/home/elysium/uclinux/nios2-linux/uClinux-dist/vendors' make: *** [vendor_hwselect] Error 2 Any suggestions, thanks
