20 years agohelp!how to build uclinux on de2 in windows
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ohmy.gif nearly all of those exllent people who built a uclinux on de2 were doing there work in linux environment.have anyone built o...
20 years ago------------------------------------------------
Microtronix Linux Extensions Version 1.4, Built June 20, 2005 ------------------------------------------------ /cygdrive/f/workspace/altera/NIOS/de2/DE2_demonstrations/DE2_NET [SOPC Builder]$ nios2-download -g Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Restarting target processor /cygdrive/f/workspace/altera/NIOS/de2/DE2_demonstrations/DE2_NET [sopc builder]$ nios2-terminalnios2-terminal: connected to hardware target using jtag uart on cable
nios2-terminal: "usb-blaster [usb-0]", device 1, instance 0
nios2-terminal: (use the ide stop button or ctrl-c to terminate) this is the response of the system after i download the project DE2_NET, and another problem is shown below 系统找不到指定的路径。 . . Removing old PATH, because a copy of . cygwin1.dll was found at: . /usr/bin/cygwin1.dll . You can remove or rename it to avoid conflict. . ------------------------------------------------ Welcome To Altera SOPC Builder Version 5.1, Built Thu Oct 20 19:10:26 PDT 2005 ------------------------------------------------ ------------------------------------------------ Welcome to the Nios II Development Kit Version 5.1, Built Fri Oct 21 00:44:38 PDT 2005 Example designs can be found in /cygdrive/c/altera/kits/nios2_51/examples ------------------------------------------------ (Executing user startup script: c:/altera/kits/nios2_51/user.bashrc) /cygdrive/f/workspace/altera/NIOS/de2/DE2_demonstrations/DE2_NET [sopc builder]$ nios2-download -g zimage_cpu_0
nios2-elf-objcopy: './zimage_cpu_0': no such file
./zimage_cpu_0.srec: unable to open input file
rm: cannot remove `./zimage_cpu_0.srec': no such file or directory
/cygdrive/f/workspace/altera/nios/de2/de2_demonstrations/de2_net
[sopc builder]$ i thought it will show the message that "Starting processor at address 0x04800000" would you please show my a way to explain and solve these problems?
