19 years ago[Help]How can I delete the DDR component!
Because I have not a valid license for DDR,so I delete DDR component in SOPC Builder GUI.And I delete files that there is "ddr" in name.But I can't compile this project in quartus!When I compile myproject.qdf,quartus shows:
Error: Tcl Script File auto_verify_ddr_timing.tcl not found Error: Evaluation of Tcl script auto_verify_ddr_timing.tcl unsuccessful Error: Quartus II Shell was unsuccessful. 2 errors, 0 warnings Error: Processing ended: Wed Dec 06 11:57:12 2006 Error: Elapsed time: 00:00:01 Error: Quartus II Full Compilation was unsuccessful. 2 errors, 354 warnings How can I solve this question?Please help me. I use quartus6.0 and I modify the project: E:\altera\kits\nios2_60\examples\vhdl\niosII_cycloneII_2c35\standard\standard.qpf4 Replies
--- Quote Start --- originally posted by liuliqiang@Dec 5 2006, 09:42 PM because i have not a valid license for ddr,so i delete ddr component in sopc builder gui.and i delete files that there is "ddr" in name.but i can't compile this project in quartus!when i compile myproject.qdf,quartus shows:error: tcl script file auto_verify_ddr_timing.tcl not found
error: evaluation of tcl script auto_verify_ddr_timing.tcl unsuccessful
error: quartus ii shell was unsuccessful. 2 errors, 0 warnings
error: processing ended: wed dec 06 11:57:12 2006
error: elapsed time: 00:00:01
error: quartus ii full compilation was unsuccessful. 2 errors, 354 warnings
how can i solve this question?please help me.
i use quartus6.0 and i modify the project:
e:\altera\kits\nios2_60\examples\vhdl\niosii_cycloneii_2c35\standard\standard.qpf
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19845)
--- quote end ---
--- Quote End --- You've got to delete and re-generate in SOPC Builder. Also, there should be a script that removes any/all DDR settings/constraints from your QSF file, unless (of course) you've already deleted that :-) Cheers, - slacker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19845)</div>
--- Quote End --- You've got to delete and re-generate in SOPC Builder. Also, there should be a script that removes any/all DDR settings/constraints from your QSF file, unless (of course) you've already deleted that :-) Cheers, - slacker <div align='right'><{post_snapback}> (index.php?act=findpost&pid=19846)</div> --- Quote End --- Hi,thanks slacker According to your words,I do the following steps: 1) open the project E:\altera\kits\nios2_60\examples\vhdl\niosII_cycloneII_2c35\standard\standard.qpf 2) delete the component DDR in SOPC ,then re-generate 3)in quartus,start full compilation,but find error message such as: Info: Command: quartus_sh -t auto_verify_ddr_timing.tcl compile standard standard Info: Quartus(args): compile standard standard Error: Tcl error: can't find package ::ddr::settings while executing "package require ::ddr::settings" (file "./verify_timing_for_ddr_sdram.tcl" line 54) invoked from within "source ./verify_timing_for_ddr_sdram.tcl" (file "auto_verify_ddr_timing.tcl" line 11) Error: Evaluation of Tcl script auto_verify_ddr_timing.tcl unsuccessful Error: Quartus II Shell was unsuccessful. 2 errors, 0 warnings Error: Processing ended: Wed Dec 06 15:40:01 2006 Error: Elapsed time: 00:00:02 Error: Quartus II Full Compilation was unsuccessful. 2 errors, 632 warnings how an I do? - Altera_Forum
You should probably remove the constraint for DDR from the .qsf file. They are usually placed at the end of the file.
--- Quote Start --- originally posted by iztok.jeras@Dec 6 2006, 03:27 AM you should probably remove the constraint for ddr from the .qsf file. they are usually placed at the end of the file.<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19849)
--- quote end ---
--- Quote End --- Thanks for iztok.jeras and slacker!Thanks a lot!The problem have been solved! I delete constraint for DDR from in the .qsf file,now my system is working fine! How magical!
