19 years agoHelp with YAFFS Format
Does anyone know if there is info on using YAFFS format with Nios? I'm looking at implementing an MP3 player, but the example design I've found on the Altera website supports FAT16 and not YAFFS. Can anyone help? Thanks, Claire2 Replies
I do not know about YAFFS but jffs2 is supported in uCLinux.
http://en.wikipedia.org/wiki/jffs2 (http://en.wikipedia.org/wiki/jffs2) IzI - Altera_Forum
Hi Claire,
I'm assuming that NAND flash is a requirement, otherwise you don't need YAFFS. In any regard you might find the following useful: http://www.ebdev.com/eos/yaffs-filesystem.pdf (http://www.ebdev.com/eos/yaffs-filesystem.pdf) YAFFS isn't in the linux tree as of 2.6.18, but the doc above is basically a howto. I've never tried to pull YAFFS into the kernel myself, nor have I ever used it. Please keep us informed about your progress :-) Good luck, --Scott
