12 years agoHelp with state machines in eclipse (NIOS II)
How can i initalise the states and cause this state machine of 3 states to work effectively.
My code if found below: # include <stdio.h># include <io.h># include <system.h># include <alt_types.h># include "altera_avalon_pio_regs.h" int main() { alt_u32 key_in, signal_raknarvarde, state; # define Scan_keys_state 0x01 # define write_to_leds_state 0x02 # define no_keys_state 0x03 // Initiering av variabler och utsignaler till hårdvaran //int state = Scan_keys_state; //int state = write_to_leds_state; //int state = no_keys_state; // loop for ever while(1) { switch (state) { case Scan_keys_state: // if key_in, state = write_to_leds; state = write_to_leds_state; break; case write_to_leds_state: state = no_keys_state; break; case no_keys_state: // Kolla att ingen knapp är nertryckt, //denna function kan göra att //wait(time); inte behövs state = Scan_keys_state; break; } } return 0; } --------------------------- Thanks for the help in advance1 Reply
You'll have to define a bit better "work effectively". A problem I see in your code though is that you don't give an initial value to the state variable. You should uncomment one of the three lines that do that.
