12 years agoHelp with Nios II linux from rocketboards.org
Hello! According to http://www.alteraforum.com/forum/showthread.php?t=42090 there is a new linux guide. So I have some question. Is uClinux for Nios II still being developed? If yes, what have b...
12 years agoThe 0xe prefix to address for io ports is correct, which bypass the cache.
I don't quite understand your question about u-boot. In typical configuration, we can seperate kernel and dts binding and u-boot pass dtb to kernel. That is, a single kernel image can be used for several similar boards, each board has a specific dtb. So you may select u-boot in kerenel config, and you don't need to specify dts in kernel config. However, dts property name is sometime related to kernel version. There is a change in usng math code from libgcc. Please apply this patch by hand. diff --git a/arch/nios2/kernel/vmlinux.lds.S b/arch/nios2/kernel/vmlinux.lds.S index db9078f..e935377 100644 --- a/arch/nios2/kernel/vmlinux.lds.S +++ b/arch/nios2/kernel/vmlinux.lds.S @@ -57,6 +57,12 @@ SECTIONS RW_DATA_SECTION(L1_CACHE_BYTES, PAGE_SIZE, THREAD_SIZE) _edata = .; + .got : { + _GLOBAL_OFFSET_TABLE_ = .; + *(.got) + *(.got.plt) + } + BSS_SECTION(0, 0, 0) _end = .; - Hippo
