12 years agoHelp with Nios II linux from rocketboards.org
Hello! According to http://www.alteraforum.com/forum/showthread.php?t=42090 there is a new linux guide. So I have some question. Is uClinux for Nios II still being developed? If yes, what have b...
12 years agoUnfortunately, that haven't helped.
As I wrote, the progress stopped at "bootconsole [early0] enabled early_console initialized at 0xe8003450". My jtag_uart has address 0x08003450. So, why is there 0xe8003450 in the output, is it normal? As I know, 0xC0000000 is added to address when using MMU, but now 0xe0000000, or am I wrong? And still there is a question about u-boot. Does kernel make (make vmImage) use u-boot config (there are options in u-boot config, which I have in my dts)? So should I look at them (u-boot option), only use dts? Thanks for help
